Cooling Fans Wont Turn On
Old Feb 24, 2003 | 11:24 AM
Bad T.A.R.A's Avatar
My fans fans will not turn on. I don't know what but if I stop at a red light my temp rises. I know I had it at the dealer over the weekend and they replace the smog pump but other than that nothing has been messed with. Any ideas on what it could be.
Thanks all
Old Feb 24, 2003 | 11:28 AM
ibanez6rg's Avatar
A way to see if your fans work is to turn on the A/C. There are three relays for the fans. 1 for the left and one for the right and one for when you turn on the heat or A/C. Another way to kick them on is unplug a sensor so it will throw an SES code and that will kick on the fans.
Old Feb 24, 2003 | 11:30 AM
So if I throw on my AC and nothing happens. What should I check.
Old Feb 24, 2003 | 11:42 AM
Please HELP!!!
Old Feb 24, 2003 | 11:47 AM
94SLUG's Avatar
If the fans dont come on with ac i would then check coolant temp sensor. No ses light? You can jump them with a battery to see if they work.
Old Feb 24, 2003 | 11:51 AM
If the fans work with a hot wire what would cause them to not to turn on.
Old Feb 24, 2003 | 06:15 PM
JJ's95B4C's Avatar
You would have to start diagnosing the problem if the fans don't turn on with the hot wire. Try first with the A/C on. If they don't turn on, let the car warm up...it will get very very high in temps, but the fans should turn on. If they turn on, its the relay that turns them on when the A/C is on. If they don't, check the other fan relays.
Old Feb 24, 2003 | 07:05 PM
96cam4ro's Avatar
Usually there are 3 possibilities.
1. The fan motor is shot. Take them out and check.
2. The 'engine controls' fuse is shot (happened to me)
3. Your PCM doesn't want to turn on the fans until a higher temperature.
Old Feb 24, 2003 | 08:34 PM
av8er's Avatar
Check your fuses. Same thing happened to me when my air pump went out. It would blow the fuse that also powered the cooling fan relays.
Old Feb 24, 2003 | 09:41 PM
luis nunez's Avatar
yup check the fuses. I had that problem, but when that happened my SES light came up
grabbem88
Apr 16, 2015 06:57 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
formula79
26
Aug 5, 2002 12:21 PM
IrocSS85
Jul 18, 2002 10:35 PM
