cooling fans not turning on
Old Sep 10, 2005 | 01:07 PM
whiTetAlt1's Avatar
Like the title says. I tried replacing 2 of the 3 relays (autozone only had 2) and they would not come on. I find it hard to believe both fans would go out at the same time. Any ideas how to fix, its realllll hot here in Texas. Thanks
Old Sep 10, 2005 | 02:10 PM
JG94Z's Avatar
Re: cooling fans not turning on
Check with the schematics. I believe you have an inline fusable link that could have gone bad. You could also check your wiring connections as they may not have a good connection.
J
Old Sep 10, 2005 | 04:35 PM
Cooling system operation and testing info
Old Sep 10, 2005 | 06:17 PM
whiTetAlt1's Avatar
Is it OK to change out the relays while the car is running??
Old Sep 10, 2005 | 09:04 PM
I can't see how it would hurt anything, but it might throw a trouble code.
grabbem88
Apr 16, 2015 06:57 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
formula79
26
Aug 5, 2002 12:21 PM
IrocSS85
Jul 18, 2002 10:35 PM
