cooling fans
Old Apr 8, 2012 | 01:40 PM
94Z28LS1toLT1's Avatar
cooling fans
Hey guys im having a problem with my fans coming on first i wanted to see if cold air comes out wheni turn the ac on but no luck then i turn it off and let it sit there and it got on the red mark i shut ut off n it boiled like hell,then i turn it on n put the ac on and then off and my fans came on hi speed n turn off at 226 now why did my car do this should i change the sensor on the water pump
Old Apr 8, 2012 | 08:09 PM
Re: cooling fans
Got worse when i got home from wrk i look at the car and ran the car as the temp climbed up the fans never came on it got to the red low or high speed never came on the fuse is good and the motors for fan r new[EDIT] car is pissing me off
Last edited by Injuneer; Apr 8, 2012 at 10:14 PM. Reason: Do not override the language filter.
Old Apr 8, 2012 | 11:13 PM
Re: cooling fans
Hook up a scanner, so you can see what temps are being read and what the fan status is.
4th Gen LT1 F-body Tech Articles
Old Apr 9, 2012 | 08:56 PM
Exclamation Re: cooling fans
Hey rob when i removed a wire for the ses light to come on the fans came on so i kno the motors of the fan work,i wouldnt need a scanner bc at the temp mark the needle is at the red and when shut the car off boiling like a tea kettle im thinking the sensor on the water pump is out,but will that throw a code?
Old Apr 10, 2012 | 05:06 PM
Re: cooling fans
That's why you need a scanner to look at the temp the PCM sees.
Old Apr 10, 2012 | 08:40 PM
Re: cooling fans
Turns out it was the sensor on the water pump now the fans come on properly
Noct
Jul 14, 2015 01:18 AM
Jmj93z28
Jul 8, 2015 10:01 PM
Jmj93z28
Jul 8, 2015 06:58 AM
warmeck
Jun 5, 2015 05:19 PM
Biggiebound
Apr 23, 2015 08:50 AM
