coolant temp sensor pigtail
Old Apr 18, 2008 | 01:20 PM
Crows89RS's Avatar
yes, i did a search on it, and someone said i needed to use the "A" terminal. so i did. basically what the problem is that i broke my coolant temp sensor in the head when doing headers. so i bought a new one, installed it, only to find that the pigtail had been melted by the headers (awesome!!), so I finally just got a pigtail today and the original pigtail only had one wire, and the new one has two.
I tried using the A terminal, still didn't work. my temp gauge sat below 0 and didn't even think about moviung even after 10 minutes of idling. all i basically did was strip about 1/8" wire from the existing pigtail wire (cutting off the old connector of course), crimped a butt connector on there, stripped about 1/8" of wire off of the new pigtail wire (the one in the a terminal), and then crimped that closed.
I tried the B terminal too, no luck. Not sure what to do... is it possible that the CTS in the water pump that goes to the PCM is faulty?
Old Apr 18, 2008 | 01:26 PM
bowtiekid's Avatar
Sounds like you grabbed a CTS for the Water pump and not the head.. I'm pretty sure they're different. Try getting a different CTS for the head
Old Apr 18, 2008 | 01:32 PM
Crows89RS's Avatar
AHHHHHHHHHHHHH I HATE AUTO ZONE. Always give me the ****ing wrong parts... i thought they were the same thing though..?
Old Apr 18, 2008 | 02:57 PM
Nope, not the same (although places like AZ think so). The dealer will have the correct one.
Old Apr 18, 2008 | 03:19 PM
9formula4's Avatar
http://www.eficonnection.com/eficonn..._pigtails.aspx
your welcome
Old Apr 18, 2008 | 03:28 PM
mdacton's Avatar
Its probly listed as a sending unit
Old Apr 18, 2008 | 08:14 PM
Counted Out's Avatar
Originally Posted by 9formula4
Great site. Fast shipping.
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
