Coolant temp sensor connector
Old Mar 1, 2014 | 09:29 PM
poposhad's Avatar
I have a 94z and I noticed that the connector for the coolant sensor along with the sensor was damaged during the removal of the exhaust manifolds. I noticed that my connector only has one wire , is that correct or should it be two wires .
Old Mar 1, 2014 | 09:57 PM
Re: Coolant temp sensor connector
You have 2 coolant temp sensors - 1 in the driver's side head for the dash gauge (1 wire); and 1 on the water pump housing for the PCM (2 wire).
Old Mar 2, 2014 | 06:20 AM
poposhad's Avatar
Appreciate the info. Thank you. Are the sensors the same, need to order one along with a new connector. Also I wanted to ask another question to you., I am installing shortys pacesetters , do you know if I can get a straight pipe already fitted to fit the end of the y pipe to the remaining exhaust, bypassing the cat.thanks again
Old Mar 2, 2014 | 09:38 AM
No. One is a 1-wire sensor that grounds through the threads in the head. The other is a 2-wire sensor that requires a separate ground wire from the PCM.
Shoebox has part #'s for the sensors, and the pigtails:
1993-1997 F-Body Part Number Collection
The shorty Pacesetters should include a Y-pipe that ends in the stock location, ready to connect to the cat, or whatever you have replaced the cat with. Normally, if you are still running a cat it is a welded connection. Yours will depend on what is on the end of the "off road pipe" that replaced the cat.
Old Mar 2, 2014 | 09:40 AM
No, the sensors and connectors are not the same. I recommend you buy only the ACDelco sensor(s).
Old Mar 2, 2014 | 04:34 PM
poposhad's Avatar
Thank you and I will take your recommendation , thanks
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
