Coolant temp sensor
Old Jul 12, 2012 | 11:40 AM
vicki711's Avatar
Coolant temp sensor
Hubby finally got his motor back (after 5 months) and they lost his coolant temp sensor. He ordered one from NAPA with the GM part number and it came with 2 prong terminals. His only has a one prong terminal on the adapter. HOW does he handle this? I've googled until Google said enough and all I can find is a 2 prong male terminal.
Old Jul 12, 2012 | 02:57 PM
mrmint69's Avatar
Re: Coolant temp sensor
I just ordered one thru the chevy dealership and it was pretty cheap. If the engine is the same with the same wiring harness, the vin number will show the part number that should work.
Old Jul 12, 2012 | 03:01 PM
1993-1997 coolant temperature sensor for gauge
AC-Delco # 213-77
GM 25037332
Either of those two numbers will get you the correct sensor.
Old Jul 15, 2012 | 02:44 AM
mikeross242's Avatar
coolant temp sensor (2 wire) is located in the water pump
coolant temp switch (1 wire) is located in the driver side head
95_Z28/SS
May 20, 2015 01:23 PM
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
