coolant temp gauge or sensor?
Old Sep 26, 2007 | 09:52 PM
  #16
mrmint69's Avatar
Auto parts stores offer free scanning. Just call them and see if any in your area offer it.
Old Sep 26, 2007 | 10:15 PM
  #17
plaf713's Avatar
i would but the car doesnt drive because it doesnt idle, i have a bunc of dilemas lol
Old Sep 26, 2007 | 11:21 PM
  #18
They just scan for codes (if OBD-II) and don't do diagnostic monitoring (which would be the most help in this situation).
Old Sep 27, 2007 | 08:19 AM
  #19
Originally Posted by plaf713
i spent fifteen dollars on the sensors, and if i bought a multimeter i wouldnt know how to use it anyways, so whats the difference
im just bad with the electrical part, screw it i'll just try and get it scanned, thanks for the help/not help
Good attitude. That will get you a lot of help around here
Old Sep 27, 2007 | 08:27 AM
  #20
plaf713's Avatar
what help have you given me otherwise? NONE!! so thank you.
Old Sep 27, 2007 | 08:38 AM
  #21
There was some help in my testing info that required no tools (for your gauge problem). Did you try grounding the sensor lead to see if it caused your gauge to move?
Old Sep 27, 2007 | 08:51 AM
  #22
plaf713's Avatar
yes i did, and nothing happened, so i bought another sensor, that was helpful. dont worry shoebox, you are always helpful, i am not talking about you
Old Sep 27, 2007 | 09:22 AM
  #23
I explained what impact the temp sensor could have, since the information in the previous post was incorrect. I'm really sorry that buying two new temp sensors didn't solve your problem, but you chose to do that before checking them out. Shoebox has detailed instructions for checking the temp sensors using a multi-meter. Anyone with minimal capabilites, AND the multi-meter could follow those instructions. Sounds like you enjoy pissing your money away.
In any case, I won't continue to annoy you with my "no help".
Have a nice day
Old Sep 27, 2007 | 09:37 AM
  #24
plaf713's Avatar
i had to buy the coolant temp gauge anyways, so i bought the coolant tempp sensor, are you my financial advisor or something? if i would like to spend the extra ten dollars on another sensor so be it. i dont understand why some people are just such jerks because i decide not to do it there way.
Old Sep 27, 2007 | 02:43 PM
  #25
Ok, if you grounded the wire with the key on and the temp gauge did not move, the sensor was not the problem. The problem is from there toward the gauge.
Old Sep 27, 2007 | 03:19 PM
  #26
plaf713's Avatar
well the firs tproblem is, i cant get it to run enough to get it hot at all, the max about 2 minutes, so i'll try it again. Is there anything that i should do to the IAC? i really need a scanner, i might try ad push it to my mechanic and have it scanned.
Old Sep 27, 2007 | 05:12 PM
  #27
To test the gauge and it's wiring to the sensor in the head, the engine does not have to run. The key just must be ON.
I know you still have the "won't run" problem, but hard to say what that is all about.
Old Sep 27, 2007 | 07:24 PM
  #28
SS RRR's Avatar
Another question is did you buy the correct sensor? Both sensors have different part numbers.
Old Sep 27, 2007 | 10:22 PM
  #29
plaf713's Avatar
well there def the right parts. Atleast i know my problem isnt in the coolant temp sensor, or atleast i believe its not in the coolant temp sensor. I might try and just rev it and make it run for about 15 minutes straight, try and get some of the old gas out of the car, try and clean out the fuel system before i try anymore with the sensors.
Old Sep 29, 2007 | 01:13 PM
  #30
Dtimekw's Avatar
plaf713 - I think we've all been where you are, frustrated, p!ssed off and pulling hair out but believe me, this board and it's members have saved me thousands of $$$. No one on here is out to screw anyone. They offer advice and share experience. I would much rather be on here than in a waiting room at the dealership.
Injuneer, Shoebox and the rest of you, keep up the good work. I for one REALLY appreciate it!!
Magenta_Hearts
Mar 29, 2017 08:54 PM
warmeck
Apr 27, 2015 04:34 PM
phoenix95
Jan 8, 2015 09:14 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
brentbrowning01
Dec 16, 2014 06:35 AM
