coolant temp gauge or sensor?
Old Sep 25, 2007 | 10:09 PM
plaf713's Avatar
my gauge does not work on my dash, what sensor do i need? the sensor that goes on the waterpump or the sensor that goes on the side of the head? a part number would also be helpful
thanks
paul lafreniere
Old Sep 25, 2007 | 10:11 PM
plaf713's Avatar
oh yeah, my car is running like **** also, i have heard that if the sensor is bad the car wont idle and will run like **** and that is exactly what my car is doing
Old Sep 25, 2007 | 10:15 PM
96z28t56's Avatar
the sensor on the head is the one that controls the gagues, but it does NOT effect the PCM.
Old Sep 25, 2007 | 10:53 PM
mrmint69's Avatar
Get it checked for codes. It could be that easy.
Old Sep 25, 2007 | 10:54 PM
plaf713's Avatar
i wish i had a scanner or i would
Old Sep 25, 2007 | 11:33 PM
SS RRR's Avatar
That is for a LS1. LT1 if the PCM sensor (located on the waterpump) is bad it'll just turn the fans on by default. You can find part numbers for most popular things at www.shbox.com
Without any information about the car or what's done to it no one can really tell you a whole lot of anything.
Old Sep 26, 2007 | 12:29 PM
If the coolant temp sensor in any engine is giving the incorrect temp to the PCM, it can cause the engine to run poorly. Low temps cause the PCM to richen the A/F mixture and prevent the system from going into closed loop. But as noted, only the sensor in the water pump housing will affect the PCM.
Old Sep 26, 2007 | 01:10 PM
plaf713's Avatar
tonight i am going to try to run the car with the coolant temp sensor out, see how it runs without it in. they couldnt be that expensive im sure
Old Sep 26, 2007 | 02:20 PM
That's not really a good idea (for reasons explained by Injuneer).
If you want to test it, there is testing info on my Tech Page. A scanner will also tell you very quickly if it is working properly.
Old Sep 26, 2007 | 03:18 PM
plaf713's Avatar
i really wish i had the proper tools, this would be a lot easier, i dont have a multimeter as well.
Old Sep 26, 2007 | 04:08 PM
plaf713's Avatar
well i bought both sensors and installed them, the car still runs like crap, still wont hold its idle, i need a scanner bad, is there anyone in the albany ny region with an obd1 scanner?
Old Sep 26, 2007 | 06:17 PM
You probably spent/wasted more $$$ on the sensors than a digital multi-meter would have cost you.
We all trash the typical dealer for playing parts roulette with our cars, and then go out and play the same game.
Old Sep 26, 2007 | 06:46 PM
plaf713's Avatar
i spent fifteen dollars on the sensors, and if i bought a multimeter i wouldnt know how to use it anyways, so whats the difference
Old Sep 26, 2007 | 06:58 PM
It's hard to work on the car without the proper tools. Unless you just want to keep throwing parts at it, you need to buy the tools and learn how to use them or take it to a shop to have the work done. There are not just a whole lot of choices.
Old Sep 26, 2007 | 07:09 PM
plaf713's Avatar
im just bad with the electrical part, screw it i'll just try and get it scanned, thanks for the help/not help
