converting LT1 intake
Old Apr 9, 2009 | 11:51 PM
1996camaroSSclone's Avatar
Is it possible to convert an LT1 intake to an LT4 intake? I noticed AFR has there 210 eliminator heads in the LT4 form and was woundering if I could use these. My engine builders around here really like AFR products.
Old Apr 10, 2009 | 05:27 AM
You would have to add metal on top of each runner, to allow the ports to be machined taller. Its been done.
Old Apr 10, 2009 | 02:16 PM
Might as well have a carb intake converted for all that work....
Old Apr 10, 2009 | 02:41 PM
96capricemgr's Avatar
What people fail to understand is the LT1 intake and LT4 intake are internally identical. Only time the LT4 intake need come into play is if the ports in the heads are much taller than LT1 heads. Don't really know how much taller those ports are till you have the heads in hand and see if you are comfortable with the material that would be left to seal the top of the port of an LT1 intake.
Old Apr 10, 2009 | 08:53 PM
I was looking at the afr 210 heads. They say they use the gen II intake but don't specify wether it's LT1 or LT4.
onefastgta
Mar 19, 2015 10:10 AM
formula218
Dec 2, 2014 04:27 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
smacz28
Aug 6, 2002 01:51 PM
