computer reader
Old Jan 3, 2009 | 12:56 PM
djskiggz's Avatar
computer reader
what computer reader do i need to buy? I heard they got one at autozone. Not quite sure what I should get. I got a 97 z28 SS
Old Jan 3, 2009 | 01:08 PM
RamAir95TA's Avatar
Are you looking to just scan codes or are you looking to delve further into the PCM? Autotap will do just that, but Autozone will scan the codes for free. There are several low-cost scanners available. A quick search will result dozens.
Old Jan 3, 2009 | 01:26 PM
djskiggz's Avatar
just looking to get the codes for now. But i also want to buy one because im going to try to fix my engine light problems myself and I think i'll need the scanner to reset the computer right?
Old Jan 3, 2009 | 02:00 PM
bombebomb's Avatar
EDIT: I stand corrected
Old Jan 3, 2009 | 08:55 PM
TTS Datamaster is only for OBD-I. He can't use it on an OBD-II PCM. One of the more usefull data logging systems for OBD-II is AutoTap.
You can get an OBD-II code reader on Harbor Freight for less than $50. Someone here bought one and tested it and found it performed well.
"Resetting the computer" in the sense he used means clearing the codes. Most (but not all) OBD-II code readers will clear the codes. If you don't mind losing the long term fuel corrections, you can pull the "PCM BAT" fuse for 30 seconds. There are some OBD-II codes that will not clear this way though.
Old Jan 4, 2009 | 07:28 AM
bombebomb's Avatar
Oh, next time I should look at his year I guess. Completely forgot about OBD-II when I made that post.
Formula Steve
Sep 19, 2023 08:31 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
