Computer problem
Old Oct 24, 2019 | 06:33 PM
  #31
Ricksc10's Avatar
Re: Computer problem
Originally Posted by Ricksc10
I changed out the injectors and no change???
I already had a set on hand so I thought what the hell
Old Oct 24, 2019 | 07:09 PM
  #32
There are four possible causes of DTC 18:
- not having ~12 volts on the pink wire at each connector. Are you sure you checked all 8 connectors correctly?
- injector resistance out of range. You already ruled this out.
- PCM not supplying a ground. I covered all of this in post #16. Did you check for a ground on each injector with a ‘noid light?
- loose, corroded or shorted injector harness wires causing intermittent circuit shorts or opens. Inspect, jiggle wires, see if the code sets.
Old Oct 24, 2019 | 08:14 PM
  #33
Ricksc10's Avatar
Yes I checked all of that . I even checked if they were all getting power when it was running bad. All ok
Old Oct 25, 2019 | 11:01 AM
  #34
Ricksc10's Avatar
I’m having a very hard time sending the diagnostic info to you. Do you have a direct email?
Old Oct 25, 2019 | 12:25 PM
  #35
I don't think reviewing the file will do much. If you are still getting DTC 18, you have to look for the wiring problem. There is nothing in the file that will solve that problem.
Old Oct 25, 2019 | 12:41 PM
  #36
Ricksc10's Avatar
Ok thanks. I removed all of the emission stuff off and it also is programmed for a 4l60e it has a turbo 400 now. None of that stuff has been removed from the computer. Could this cause this problem? This weekend I’m going to take the harness apart and look at it very closely.
Old Oct 27, 2019 | 07:29 PM
  #37
Ricksc10's Avatar
You were correct. The problem was wiring. I had to completely rewire the fuse block. There were several bad wires. Thanks for all of your help
Old Oct 28, 2019 | 12:37 PM
  #38
Glad it worked out for you. Thanks for the followup, so we know what the problem was. Wish everyone would do that.
MrHyde
May 11, 2015 10:26 PM
blackbirdta
Jan 21, 2007 11:16 AM
94 TA TT2S
Oct 1, 2004 09:21 PM
96ta(nick)
Sep 13, 2004 03:15 PM
95_Blk_Z28
Aug 26, 2004 06:16 PM
