compression test psi.
Old Mar 19, 2007 | 08:00 PM
itzkwik's Avatar
what should the psi approx. be for 11.1 cr ?
Old Mar 19, 2007 | 09:06 PM
mrmint69's Avatar
I believe if you are testing them individualy you need them all within a certain range not just a set number.
Old Mar 19, 2007 | 09:10 PM
itzkwik's Avatar
I checked 4,6and 8 and got from 165 to 175psi
Old Mar 19, 2007 | 09:35 PM
formula14.18's Avatar
not to steal your thread how hard was it to check number 8
Old Mar 19, 2007 | 09:41 PM
itzkwik's Avatar
piece of cake unless i have 7 and 8 backwards , driverside is what i checked, pass. side ,jack car up and pull starter ,much quicker
Old Mar 19, 2007 | 09:59 PM
96capricemgr's Avatar
Did you keep the throttle wide open?
Cam comes into play but my bone stock wagon with 10:1 at 180K miles cranked 195-200 and my heads/cam 100K mile Caprice at a static 11.5:1 cranked like 225-230.
Old Mar 20, 2007 | 11:43 PM
Driver's side is #1/#3/#5/#7
Old Mar 21, 2007 | 07:10 AM
SS RRR's Avatar
As said it depends on the cam profile. My LPE cam with heads on a stock bottom end tested at 210psi whereas my GM847 was right around 175. Rule of thumb is all cylinders should be w/in 10% of the highest value.
KYWes
Jun 14, 2022 06:52 AM
Quickss96
Jan 29, 2016 05:56 PM
karpetcm
Aug 14, 2015 03:02 PM
13qtr
Jul 19, 2015 05:30 PM
asilomar244
Jul 12, 2015 05:53 AM
