compression test with hooker lts???
Old Oct 6, 2005 | 06:36 PM
Gary 95 Z28 M6's Avatar
has anyone done a compression test with hooker lts installed on the car? i am trying to track down my oil consumption/burning problem and im in the process of doing a compression test and cylinder leak down test on the car. i did the left bank no problem but i cannot for the life of me get the tester to screw into any of the spark plug holes on the right side. is there any other way to do it without removing the header?
Old Oct 6, 2005 | 07:17 PM
SS RRR's Avatar
Re: compression test with hooker lts???
Nope.... You don't have to remove the header completely. If you have ARP 3/8" 6/12point header bolts then it shouldn't be a real big deal.
Just take all the header bolts and collector bolts off your Y-pipe and work the header down so you have better access.
Old Oct 6, 2005 | 09:23 PM
yeah i was thinking of just unbolting the header and letting it fall down a couple inches. thanks for the tip!
Old Oct 7, 2005 | 06:19 AM
cehan's Avatar
I have Hookers and was able to get to all the cylinders without loosening or removing the headers. #2 & 4 were kind of aggravating, on #6 & 8, I had to go from underneath and remove the starter.
Chris
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
13qtr
Jul 19, 2015 05:30 PM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
