Compression Test
Old May 15, 2006 | 08:01 PM
matLT1's Avatar
Compression Test
I will be performing a compression test on my car tomorrow. I was curious as to what you guys did to disable the ignition and fuel system. I have read that you can simply pull the PCM BAT fuse and that will disable both. Have any of you tried this? Thanks
Old May 15, 2006 | 11:19 PM
Re: Compression Test
Pulling the PCM BAT fuse disables both fuel and spark (since the PCM is basically disabled).
KYWes
Jun 14, 2022 06:52 AM
Quickss96
Jan 29, 2016 05:56 PM
cmsmith
Sep 14, 2015 09:25 PM
karpetcm
Aug 14, 2015 03:02 PM
13qtr
Jul 19, 2015 05:30 PM
