Compression Test
Compression Test
I will be performing a compression test on my car tomorrow. I was curious as to what you guys did to disable the ignition and fuel system. I have read that you can simply pull the PCM BAT fuse and that will disable both. Have any of you tried this? Thanks
cmsmith
Sep 14, 2015 09:25 PM
