compression ?'s
Old Mar 8, 2004 | 09:30 PM
fstenuf's Avatar
compression ?'s
what do you do when you find a bad cylinder, bent push rod? broke spring? idk:S what causes 1 to have low compression? i'm having a compression test done this week to find the bad one. its haveing trouble turning over and my mechanic told me that there was a cylinder missing. and my car likes to lug forward (idk if thats the best way to describe it) when i'm drivingin any gear at any rpm. thanks for the help
Old Mar 8, 2004 | 09:38 PM
Red96Lt1's Avatar
Usually the rings are worn or the valves aren't seated properly. I broken spring could do it.
Old Mar 8, 2004 | 09:40 PM
fstenuf's Avatar
how do you seat the valves properly? the motor has like 8k on it. i really hope its not warn rings that wouldn't be good any other suggestions?
Old Mar 8, 2004 | 09:47 PM
fstenuf's Avatar
anyone have any ideas how much it costs to change the rings? i think the rate of the shop is like 50 bucks an hour. how long of a job is it? any help would be great.
Old Mar 8, 2004 | 10:00 PM
fstenuf's Avatar
well if it $1350, i'm dicked. lol well high performance cars require high performance maintance! i just hope its a busted spring or somthing not too major. well it gets checked on thurs. any other possibilities on the situation??
thanks
Old Mar 8, 2004 | 10:39 PM
fstenuf's Avatar
TTT
Old Mar 9, 2004 | 01:20 PM
grumpygreaseape's Avatar
thats a pretty big leap. the motor has 8k miles and someone is talkin a compression check. first off-if it is having problems turning over-im assuming you mean when you start it up, prolly worse when hot, its cranking slow thats aint nothin to do with low compression. ok, theres that. now generally, speaking from my 20 plus years (yikes thats scary) of repairing cars, compression checks and all the related labor and time required to perform one-especially on these friggin things-they are a thing of the past-cant your guy set it on his scope\analyzer and do a quickie power contribution test, if he is so concerned a hole isnt up to spec. mechanically? has he even suggested a scope check of the secondary ignition system? thats without a doubt the first place to go and look, based on what you have written in your post. has anyone started at the simple end of the diagnostic spectrum before the "got a missing cylinder" diagnosis. i would ask some black and white yes no questions before i buy into a ring job. fyi heres some contributing causes for lack of power contribution from a single cylinder in a multi cylinder engine (gasoline) burnt valve, burnt seat, valve siezed in guide, sometimes intermittently, worn rings, bent con rod,individual runner intake leak, bad injector, bad injector driver, intermittent or continuous power short to ground, ground short to power, faulty egr valve, passages, or controls, lifted head, cracked head, cracked block, cracked spark plug, cracked distributor cap on and on and on it goes. get a mechanic who will get you an accurate written diagnosis in no more than an hour shop diagnostic time. at the most. unless its something like this-"well you have got low compression on whatever cylinderfillintheblanks and at a minimum the head needs to come off to ascertain the cause of the low hole" and with that he will likely be able to give you the worst case dollar figure on top of the r and r labor. sound like a second opinion wouldnt hurt.
Old Mar 9, 2004 | 11:29 PM
fstenuf's Avatar
any info on why my car wants to lung forward or "jerk" idk how to explain it. but thats what its doin is wantin to jerk forward on me no matter how fast its goin. thanks for the help so far
Old Mar 9, 2004 | 11:53 PM
fstenuf's Avatar
also in order for me to get it to start i have to hold the gas to the floor, it still takes a couple turns but it does start idk what to do someone please help so i can get my baby up and runnin again
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
