Compression ratio question
Old Oct 26, 2005 | 03:32 PM
Colin91Z's Avatar
I have a set of heads that have been milled .010, with a stock deck height, and a stock bottom end. What will my compression ratio be if I use a .026 thick head gasket such as Mr Gasket 5716s? Thanks
Old Oct 26, 2005 | 04:53 PM
turbo_Z's Avatar
Re: Compression ratio question
I guess and I say guess b/c I dunno the exact cc of the combustion chambers but its between 11.1 and 11.4.
Old Oct 26, 2005 | 05:25 PM
Colin91Z's Avatar
Well, stock the chambers are 55cc (I think) and my chambers have been polished so that might add a coulple of cc's, but I would think that being milled .010 they would still be very close to 55cc. Basicly I'm wanting to get 11 to 1 out of it. So you think the .026s will get me there?
SStrokerAce's Avatar
Your chamber is now about 1-2cc smaller, and you have about a -6cc valve relief, pistons .030 in the hole.... around 11.0-11.1:1
Bret
Old Oct 26, 2005 | 05:34 PM
FastZinTennessee's Avatar
Damn I didn't know the pistons were .030" in the hole! I was putting in .020" and using a smaller combustion chamber and coming up with around 11.5:1, which I knew couldn't be right.....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
pimpss96
Feb 12, 2015 01:28 PM
