compression check..
compression check..
only checked one cylinder cause thats all i had time for.. (my dad found his tester lyin around so i put it to use ) but how is 120 for an LT1 with 150k miles, front driver side cylinder was only one checked gonna check em all when i change the plugs and put headers on next week
Re: compression check..
Doing a check on a single cylinder isn't really very meaningful. The pressure will be dependent on too many factors.... how many cranks, was the cylinder wet, engine temperature, were all the plugs removed, were the throttle blades blocked open, how strong is the battery, etc.? Generally you test all the cylinders and look for consistancy, which is more important than the absolute pressure numbers. With a warm engine, plugs pulled, open throttle blades blades, dry cylinders and maybe 4 rotations, I would expect something in the range of 180-200psi.
O_O wow, well the engine was slightly warm, but the throttle blades were closed far as i know and only turned it over once. but whats the difference with having all the plugs removed?? (im really new to all this stuff so more detail would be nice lol) this was one of those that screws into the spark plug hole, maybe im missin somethin and theres different ways to check it *shrug* like i said i dont know much about engines aside from what i read on here occasionally.
you have to hold the throttle all the way open and pull the coil wire so that it doesnt start. when the throttle is closed, you have a vacuum on the intake side of the motor. let it turn over at least 4 times.
Removing the plugs takes all the compression load off the starter and lets the engine crank a lot faster.
Pulling the coil wire off still leaves the injectors dumping fuel into the cylinders. By the time you get to the last one, you'll get a huge pressure, because the cylinder will be filling up with fuel. Disable the injectors.
Wouldn't pulling the pcm fuse on the drivers side of the dash between the door and the dash in that fuse box be a lot quicker/easier than unplugging each individual injector?
yep first time with anything engine related, but ive been around the fuses quite a few times just foolin with the fog lights and stereo.. so if the pcm fuse is the easiest way then thats what ill do so then, hold throttle on the floor and turn it over 4 times for EACH cylinder? or 4 times then just to each cylinder.. well, thanks for the info everyone now im curious to see what its gonna read on all 8. so i should be lookin for around 180 under those conditions warmed up right?
surreybrad
09-29-2015 09:00 PM
