Compression
Old Oct 7, 2003 | 03:48 PM
badazzcamaro97's Avatar
Compression
I need to know what the stock compression ratio and what would be the best piston to run to stay about the stock ratio.
Old Oct 7, 2003 | 03:50 PM
Got-LT1's Avatar
Stock compression ratio in the LT1 is 10.4 to 1. Can't help you on piston choice.
Old Oct 7, 2003 | 04:46 PM
What other changes are you making? Overbore for the new pistons? Anything else?
Old Oct 8, 2003 | 12:20 PM
I plan on rebuilding to stock compression and add a vortech supercharger.
Old Oct 8, 2003 | 02:56 PM
Got-LT1's Avatar
Not a great idea. With stock compression and 6psi of boost, your compression ratio will be around 14.8 to 1. Way to high for pump gas.
Old Oct 8, 2003 | 08:45 PM
I was using the project shadow from PHR as a reference, they did the same, what should I do different?
Old Oct 8, 2003 | 09:08 PM
KCFormula's Avatar
Drop down to at least 9.0:1cr with a blower. Rule of thumb= you will always make more boost with boost than you will with compression.
Old Oct 8, 2003 | 09:15 PM
If I was to run 9.0:1 compression with the vortech supercharger with 6psi, what kind of power would I be looking at
Old Oct 8, 2003 | 09:29 PM
kmook's Avatar
Advanced Tech Moderator
I think he meant you will make more power with a lower c/r and more boost, than a higher c/r and less boost.
Old Oct 8, 2003 | 09:31 PM
kmook's Avatar
That just depends on your setup. What heads, what cam, what exhaust, what tune....
Old Oct 8, 2003 | 10:05 PM
I would be running ported stock heads with a mild comp cam and 1.6 rockers
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
