Compatibility: Different computer
Old May 23, 2020 | 05:58 PM
Robb676's Avatar
Ok, Lets try this:
My Camaro is a 1997 Z28 with the LT-1 and the 6-speed manual.
The engine had a very loud knock at idle so I bought a rebuilt LT-1. The numbers match engine for engine but it came with a different computer.
Computer that came with rebuilt engine
Computer that came
Rebuilt motor
original motor
with the 1997 Camaro
Now my issues or questions are;
- Will the rebuilt engine work with the computer that came the rebuilt motor? The rebuilt engine came with a egr block off, some vacuum plugs on the throttle body ect....
- I'm adding some long tube headers that have the provision for the O2 sensors.. I um assuming they will go to the computer.
I guess what I'm asking will this all work, and what do I need to make it work?
Any info that you can give me will be greatly appreciated.
Sorry I dont see how to delete the duplicate photos
Old May 24, 2020 | 08:29 AM
Germansheperd's Avatar
Re: Compatibility: Different computer
What year is the rebuilt engine out of? Timing covers/sensors changed over the years.
Old May 24, 2020 | 11:32 AM
Is the rebuilt engine a 96/97 F-Body LT1? Is that what you mean by "the numbers match engine for engine"?
If so, you don't need to use the PCM that came with the rebuilt engine, just keep running the one in your car. And just use the existing harness.
There are very few differences between a 94/95 "OBD-1" engine and a 96/97 "OBD-2 engine.... nothing that can be corrected with a few parts swaps. The main one is noted above, with regard to the 96/97 having a crankshaft position sensor that is used to detect misfires. But at long as you are putting a verified 96/97 engine into your car these are non-issues.
If you are concerned that the rebuilt engine has a blocked off EGR and vacuum caps on the throttle body, simply swap those parts/vacuum lines from your old engine.
As far as adding the headers, and relocating the pre-cat O2 sensors to the header collectors, the only thing you typically have to do is get extensions for the wiring harness long enough to plug into the sensors. Do you plan to retain your cats, and the existing after-cat O2 sensors?
Old May 24, 2020 | 06:26 PM
Robb676's Avatar
All that I want to verify is that the rebuilt motor will work, and if not what will make it work. The rebuilt has a lot less vacuum and coolant lines to connect.
If I could go old school I would. I have never dealt with PCMs and such.
I like the way that the rebuilt motor has a lot less connections to make.
The numbers that are cast into the blocks match. The last 3 numbers are 327.
Ideally, I would like to drop it in and go. I dont care about the smog stuff as it will be used "off road".
My main concern is that I want to use the computer that came with the rebuilt, there is a lot less stuff on the rebuilt to hook up compared to the original that I pulled out. It was running with the old computer in a S-10.
Old May 24, 2020 | 06:49 PM
All LT1 engines have the same block (see ***), and the block casting number ends in 327. The block could have been used in a 92-96 Corvette (*** in which case it has 4-bolt mains), a 1996 Corvette LT4 limited production engine, various years of the Chevrolet Caprice, SS, Buick Roadmaster, and Cadillac Fleetwood, all of which were fitted with cast iron heads, milder cam, etc., or a 93-97 Camaro or Firebird.
The water pump configuration varies with application. The changeover to a vented Optispark distributor occurred in various years depending on application. The 96 and 97 have a different timing cover, to accommodate the crankshaft position sensor added in OBD-2, the number of knock sensors and the impedance of the sensor varies with application. Different computers were used varying with application.
Essentially “327” only tells you it's an LT1 or LT4 engine, very little about the heads, internals, accessories, etc.
Worth reading:
https://www.enginebuildermag.com/199...-lt1-engine-2/
Old May 24, 2020 | 07:25 PM
Robb676's Avatar
Thanks for the reply inguneer, but what more info do I need to give? You seem to have a lot of comments but nothing that helps.
Old May 24, 2020 | 07:31 PM
Sorry to waste your time.... somebody else may be able to meet your requirements.
Old May 24, 2020 | 07:34 PM
Robb676's Avatar
You see, platitudes.
If any one can tell me what the difference in the computers are?
Old May 25, 2020 | 07:07 AM
PCM Service # s
94=16188051 OBDI
95=16188051 OBDI
96=16214399 OBDII
97=16242921 OBDII
Old May 25, 2020 | 01:17 PM
Robb676's Avatar
Thanks for the reply,
I take it I have a motor that was set up with a OBD1 and I want to use it in a car that was set up with OBD2. Can this be done?
Old May 25, 2020 | 01:42 PM
Robb676's Avatar
I see that the computers can be reprogrammed. Which one should I get reprogrammed?
Old May 25, 2020 | 03:10 PM
sbs's Avatar
sbs
Post #3 in this thread answers your question:
https://www.camaroz28.com/forums/lt1...mputer-888292/
1982z28with18s
Oct 5, 2008 11:58 PM
lt1junkie
Mar 2, 2008 04:15 PM
Quicksilver383
Feb 19, 2007 11:17 AM
redbird ls1
Sep 21, 2003 11:49 PM
brand-x
Sep 1, 2003 08:57 PM
