Comp XFI 292 Question
Old Jun 19, 2007 | 07:25 PM
97ramairta's Avatar
is a that cam too big for a 355 LT1 with RGR Stage 2 heads...flow in the 300 ish area @ 550. 2.02/1.57 Ferrera valves and other supporting mods
Old Jun 20, 2007 | 06:25 PM
97ramairta's Avatar
anybody??
Old Jun 20, 2007 | 06:56 PM
speed_demon24's Avatar
Too big for what? It depends what you are using the car for, you can't expect anyone to give you an answer without any info on the car or setup.
Old Jun 20, 2007 | 07:05 PM
97ramairta's Avatar
Stock LT1 block bored .030 over with KB pistons
RGR Stage 2 Heads from Speed Inc.
ATI Harmonic damper...undrived
March Alt. underdrive pulley
Comp 1.6 SA rockers
Comp chromoly PR
LS7 lifters
stock 95 intake ported for 58mm tb...soon to have it sent off to have the runners ported too
BBK 58mm TB
Racetronix 42lb injectors
Racetronix LT1 fuel system...walbro 255 pump and hot wire kit
Aeromotive AFPR
1LE intake elbow
SLP CAI
Hooker Super Comp coated longtube
Hooker Y-pipe
SLP Loudmouth Exh
complete MSD ignition....opti, 6al, coil, wires
!AIR, !EGR, !A/C
M6 with Strange 12 bolt with 4.10's
Old Jun 20, 2007 | 07:11 PM
SStrokerAce's Avatar
It's a 355, IMHO it's too big reguardless of the heads you have.
Old Jun 20, 2007 | 07:18 PM
97ramairta's Avatar
thanks
Old Jun 20, 2007 | 08:05 PM
LALT1's Avatar
For what its worth I am running it on a stock cube motor, with a very nice set of heads, makes awesome power, and is more drivable than the CC306. Also have put it in a couple of customer cars no bigger than 355's and all have loved it. Not sure why everyone has only negative comments on it.
Old Jun 20, 2007 | 08:44 PM
How about some track and/or dyno #'s? I still haven't seen anything remotly impressive out of any of the XFI cams.
Old Jun 20, 2007 | 08:56 PM
LALT1's Avatar
Well I Picked up 26 HP over my CC306 and went from running 8.0's to a 7.81. I hope that helps you out some. Seen similar or better results in customer cars as well. The Mid range Torque on this cam is unbelievable compared to the 306 was.
Old Jun 20, 2007 | 09:11 PM
tnmotown's Avatar
I must say this cam rocks!! For an "off the shelf" cam (not custom grinded) it has lots of power. I know i have a 383 instead of a 355 and it pulls hard all the way to 6800rpms easy. Sorry i dont have any track/dyno numbers because im still trying to save up money from what this whole project has costed me. Im hoping for 400RWHP with a good dynotune and somewhere in the 11's if i get a good 60ft and my stock 10 bolt dont explode!
I think you should be fine with the cam and would be happy with the results. Make sure you have a good clutch to that will grab and go
Old Jun 20, 2007 | 09:21 PM
97ramairta's Avatar
the clutch is supposed to be a spec stage 3 from what i was told when i bought the car....havent tore it apart to look...
Old Jun 20, 2007 | 09:46 PM
The Engineer's Avatar
I'm not sure if the XFI-292 is too big for your engine, however, I love that cam in my 396 w/ AFR 195s!
WD
Old Jun 20, 2007 | 09:52 PM
97ramairta's Avatar
im glad to hear good things about this cam...im having a hard time deciding which cam to get for my build. i've only changed my mind about 5 times already...LOL
Old Jun 20, 2007 | 09:55 PM
LALT1's Avatar
I had the same debate. I talked with Brett and a few others, none of the Custom guys was quick o offer what I wanted out of it. I had teh 306, worked on a couple with the 847 and such, and just decided to try this one. was a great move, and it has sold several others on it also.
Old Jun 20, 2007 | 10:06 PM
97ramairta's Avatar
so you like the 292 better than the gm 847?
