Comp XFI 292 Question
Old Jun 20, 2007 | 10:08 PM
  #16
LALT1's Avatar
Much better, mor emid range torque and more peak power.
Old Jun 20, 2007 | 10:10 PM
  #17
97ramairta's Avatar
good stuff...i think ill just go ahead and order it then
Old Jun 20, 2007 | 10:12 PM
  #18
Danny McAdams's Avatar
I have darn near exactly what 95ramairta has except I have an alum. FW and 6" rods for that reason I bought the XFI280 really wanted the 292 but did not want to give up the midrange I would lose due to /alum FW. I got the dreaded beehive springs, keepers and rets. Aron the CC rep. was going to go pick the springs himself to be sure I got the new ones and assured me they will stand behind their product. BTW they have 3 techs investigating the 918 failures. I hope I am not disappointed with the 280, only time will tell. Danny Mc
Old Jun 20, 2007 | 10:19 PM
  #19
SStrokerAce's Avatar
Sorry but the thoughs of "midrange TQ" with a 242/248 113LSA cam makes me laugh. Sorry but the dyno numbers don't prove that. The XFI280 is a ten times better choice in that motor.
Bret
Old Jun 20, 2007 | 10:24 PM
  #20
speed_demon24's Avatar
I'de wait for someone to post some results that are actually impressive with any of the xfi cams before i bought one....
Old Jun 20, 2007 | 10:31 PM
  #21
97ramairta's Avatar
so what does the cam experts recommend for my set up then...
Old Jun 20, 2007 | 10:36 PM
  #22
It depends what you want out of the cam, drivability, rpm range, ect.
Old Jun 20, 2007 | 10:44 PM
  #23
97ramairta's Avatar
good mid range cam, not gonna try to turn 7k...driveability needs to be decent, i want a rough idle
Old Jun 20, 2007 | 10:55 PM
  #24
Sounds just like the cam I have in my car now, great midrange and a 6500 RPM shiftpoint.
Old Jun 21, 2007 | 06:39 AM
  #25
bowtiepwr's Avatar
>so would you consider the Crane Cams #104241?
http://www.cranecams.com/?show=brows...tType=camshaft
while using your 1.6RR???
Old Jun 21, 2007 | 10:36 AM
  #26
The Engineer's Avatar
I believe I would choose the Hot Cam for a 350CI engine over the Crane cam you listed. Too small in both lift and duration.
WD
Old Jun 21, 2007 | 10:41 AM
  #27
That's kinda what I was thinking.
Old Jun 21, 2007 | 07:50 PM
  #28
LALT1's Avatar
Bret
Sorry but again I will have to disagree, over 400ft lbs from 2900-5400 is pretty good for 350 CI IMO!
Old Jun 21, 2007 | 09:57 PM
  #29
So where is the dyno graph and track #'s (e.t. trap and raceweight?) And is your car N/A? I kinda noticed the Vortech in your sig...
Old Jun 21, 2007 | 10:02 PM
  #30
LALT1's Avatar
Sorry sig is out of date, I will revise now, that was NA'ed. 414 on torque, 422 on power. 7.81 @ 93 on motor in 1/8th only been out one time on set up, engine has been together with this set up for about 8 weeks.
I am not trying to argue with you, but this is a very common debate about any cam and most of the time the answer is simply go custom. There is some great off the shelf cams out there and I have put this in my 350, and everything on up. Has responded awesome. You asked for some numbers and I have provided them.
