Comp CC 305 vs. Comp CC 306
Old Aug 29, 2007 | 07:52 AM
  #31
raroz28's Avatar
get a custom grind. that's the only way. off the shelf cams will never get you exactly want you want. If you want to get the most power out of the 306 you'll have to rev higher than you're wanting to. So just throw that out. This isn't something you want to half *** on. Get exactly what you want from a place that does custom grinds. Check out cmotorsports.com
Old Aug 29, 2007 | 09:22 AM
  #32
chrism400's Avatar
Originally Posted by raroz28
get a custom grind. that's the only way. off the shelf cams will never get you exactly want you want. Check out cmotorsports.com
A custom grind will be your best choice for sure. It takes all of the guesswork out of it. However, there are some off the shelf grinds that are fairly cheap and will get you close. I like the fact that you have 4.10's - I had 4.56's with the 503 and a 4k stall. Perhaps one of the newer XFI profiles is for you. I would strongly suggest something like the 268XFI HR-13. Don't skimp on the valvesprings with that cam. And, use 1.6 rockers with it as it was designed to be used with 1.6 rockers.
Old Aug 29, 2007 | 09:47 AM
  #33
1986RX7's Avatar
im upgrading all the valve train just trying to figure out wat cam, its just im tryin to decide between the 503 and 305 those are my choices as i can get both dirt cheap just which of THOSE two are for me? Remember Lots of power from 2-6k
Old Aug 29, 2007 | 11:49 AM
  #34
Javier97Z28's Avatar
Moderator
SERIOUSLY. Make your own thread and quit hijacking this guy's thread.
Old Aug 29, 2007 | 02:55 PM
  #35
rasputin's Avatar
rather than trying to get the best cam for the money, take off your heads, and get a valvejob and have them do a pocket port. that way you can have a medium sized cam that will make the same power as a cc306 but without the revving and harshness on the valve train.
Old Aug 29, 2007 | 03:49 PM
  #36
zx1216's Avatar
Or just do a damn SEARCH and stop asking what will work when 500 people have told you allready. Why ask if you are limiting yourself to the two cams anyway, just pick one and go with it
Old Aug 29, 2007 | 03:57 PM
  #37
MeanGreen97Z's Avatar
CC503 with a set of ported heads is going to be an awesome setup. Not the 305 but yes to the 503!
Old Aug 29, 2007 | 05:47 PM
  #38
anilator's Avatar
So me have ing LT's and a manual i think i can eak out close to 350, what did u spin the motor to i dont really wanna go over 6k maybe 6200
6200 shifts for me.
13qtr
Oct 28, 2016 08:11 PM
truecontr3
Oct 11, 2015 09:30 AM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
