Comp CC 305 vs. Comp CC 306
Old Aug 28, 2007 | 08:34 AM
black96z28's Avatar
Which cam is going to be the better choice for me, I have the mods that are in my signature, plus I am in the process of adding a 58 MM TB, Pacesetter long tube race headers, FP regulator, heads and intake ported and matched, and 1.6 RR......also while were at it which is the best choice of 1.6 RR to go with. On top of this I am going to be running a 150-200 shot of NOS, so I am trying to make sure I make the right choice in cam, trying to get everything to compliment each other to the best I can and for the right price......
Old Aug 28, 2007 | 09:21 AM
White96Z28's Avatar
Well it's really going to depend on the heads. If the heads will support it, the 306 will make more power, but you're going to have to wind the motor up higher to get it. Who ported your heads? Do you have flow numbers on them? We really need to know what you're working with in order to match them up properly. As far as roller rockers go, the Comp 1.6 Pro Magnums are really strong and are actually as light or lighter at the valve than aluminum rockers.
Old Aug 28, 2007 | 09:39 AM
black96z28's Avatar
the heads are going to flow in the neighborhood of 270cfm with 1.940 intake valves............and the intake is going to be ported to match.....
Old Aug 28, 2007 | 09:42 AM
wrd1972's Avatar
Depends on your needs.
The CC305 powerband will be slightly higher than stock cam but make significant more power. The manners of daily driving like stop and go will be better because of the better low end power. It will rev to around 6.3K RPM on ported heads.
The CC306 powerband will be much higher than stock and make the most power of the two cams. The manners of daily driving compared to stock cam will be impaired some but this is a matter of opinion. Many people complain about cam surge and bucking when daily driving at RPM's less than 3K. It will rev to 6.6K with ported heads. This cam wants to rev high.
You need to decide what fits your needs.
Old Aug 28, 2007 | 09:54 AM
Javier97Z28's Avatar
Moderator
I'd go for a GM847 over a CC306 personally...
Old Aug 28, 2007 | 10:01 AM
1986RX7's Avatar
Not to hijack but i have a Lt1 with Full Exhaust, and Gears, and i dont wanna rev past 6k(170kmile motor) but id also like to make atleast 350rwhp with a camn, full boltons and Tune, can the 305 do this for me?
Old Aug 28, 2007 | 10:03 AM
Moderator
You don't want to rev past 6k? Forget a cam and look elsewhere...
And no, a cc305 won't get you 350rwhp on stock heads.. especially if you choke it to 6k rpm.
You gotta pay to play.
Old Aug 28, 2007 | 10:09 AM
wrd1972's Avatar
Not without ported heads, maybe ~330 RWHP.
Old Aug 28, 2007 | 10:25 AM
1986RX7's Avatar
where would u suggest shifting at then 6200?
Old Aug 28, 2007 | 10:27 AM
1986RX7's Avatar
so wat would be the best cam for performance and sound and that i can shift at 6200?
Old Aug 28, 2007 | 10:29 AM
zx1216's Avatar
See sig, flowing that much you want the 306 or larger to make the most of the heads, my numbers are on the stock heads and lower end. I shift at around 6600
Old Aug 28, 2007 | 10:34 AM
96m6lt1's Avatar
before you even do a cam or ported heads i personnally think with the mileage you have stated, you should freshen that Lt1 up. new performance bearings,oil pump,timing chain,new rings if the bore is still within spec. at this point you can spin this motor the way it needs to be.
forget that old cc3o6,847 style is the way to go,you will thank yourself later on...
Old Aug 28, 2007 | 10:37 AM
kgkern01's Avatar
I would be worried about installing any cam in a 170k motor, even if you did keep the revs down. That's asking for a rebuild IMO.
Old Aug 28, 2007 | 10:48 AM
1986RX7's Avatar
if it blows it blows...just leave it at that lol, do u guys like the sound of the 305 im torn between that an cc503 which would be better to spin to 6-6200
Old Aug 28, 2007 | 11:05 AM
MEAN LT1's Avatar
Its already been done numerous times, granted both cars reved to 6200 but none the less got there. both cars were M6.
