Are comp camshafts hollow or solid?
Old May 26, 2010 | 10:46 AM
Rob94hawk's Avatar
Are comp camshafts hollow or solid all the way through for the LT1?
Old May 26, 2010 | 11:51 AM
Slick-Z's Avatar
Solid Roller cams buddy and made of steel due to the constant stress they are under.
Old May 26, 2010 | 12:00 PM
WS6T3RROR's Avatar
Solid. Then there are cast and billet cores, and then there are different kinds of billet cores.
As a side note, the lsx cams are rifle drilled.
Old May 26, 2010 | 12:23 PM
Slick-Z's Avatar
I was generally speaking for the roller cams that came in the lt-1 which were the solid roller steel cams. I dont do lsx man
Old May 26, 2010 | 12:32 PM
The LT1 uses hydraulic rollers, not solid rollers.
Old May 26, 2010 | 06:08 PM
LearJet's Avatar
I believe he was referring to the fact that the cam is solid, not hollow, since that was the OP's question. And actually the cam is not hydraulic, the lifters are. The cam is just a solid piece of steel with a bunch of bumps on it
Old May 26, 2010 | 10:14 PM
Given the sentenced structure, your guess is as good as mine.
Old May 27, 2010 | 08:33 AM
Slick-Z's Avatar
Yes i was referring to the actual piece being solid. And yes copy that on them being a hydraulic roller cam. This is understood and i appreciate the hospitality. I just hope the original question from the person whom started the thread actually got the advice he was seeking rather than just seeing some people arguing over whom is right as is usual with some of these people on this site.
Old May 27, 2010 | 09:03 AM
Rob94hawk's Avatar
I was thinking maybe you can get an aftermarked cam rifle drilled like the LSx cams.
Old May 27, 2010 | 01:55 PM
tanmanski's Avatar
why would you want to?
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
