Comp Cams R Lifters, Why have yours failed or not?
Old Sep 1, 2005 | 02:30 PM
  #61
SuperDavez28's Avatar
Re: Comp Cams R Lifters, Why have yours failed or not?
I had the OEM style lifter and the rockers kept coming loose. I wouldn't say those are a sure thing either. Then again I had a clown for a mechanic, talking to a retard at comp, trying to figure out the valve lash on crappy lifters that never wanted to pump up. So idk who to blame, but ill be using morels for the 383. Anyone want an OEM set with 10 miles on them? 2 might be bad....20 bux lol
Old Sep 1, 2005 | 02:31 PM
  #62
JustNO's Avatar
Originally Posted by ktg
I finally got an address to send mine back. We'll see what they have to say. As for race only, that's BS. Nowhere on the package or instructions did mine say anything like that.
Race only?? R style comp lifters are for racing?? No they are for high reving engines..
Old Sep 1, 2005 | 03:39 PM
  #63
SStrokerAce's Avatar
Hey there is always ebay..... you can also just get one or two lifters to make a set and sell them on ebay for enough coin.
Bret
Old Sep 1, 2005 | 04:31 PM
  #64
Steves396lt1
Guest
Posts: n/a
Originally Posted by SStrokerAce
Guys,
I don't mean to recheck them. Install the parts, run the motor to get it hot. Tear it down and redo the rocker preload. That's it they should work like a champ after that.
I do agree that there are zero instructions and you have to know how to do it. With that being said they shouldn't fail if you put more preload on them.
Comp is not a bad company do deal with if you are a dealer and you understand the ins and outs of what is going on with all the parts. At the end consumer level it's not the best thing.
Bret
Bret , this is great, we got Comp Cams to assist in this, the forum members are officially informed, and COmp Cams will now help.
I did do the reload check after I initially started the car as it was loud. It still sound like a sewing machine, but it runs.
Old Sep 1, 2005 | 04:52 PM
  #65
Z95m6's Avatar
You're crazy.
The lifters are still junk, and i'd rip them out asap.
Old Sep 1, 2005 | 04:58 PM
  #66
Loadre's Avatar
Called 5 times today and didn't get ****.
Old Sep 1, 2005 | 05:06 PM
  #67
Steves396lt1
Guest
Posts: n/a
Originally Posted by Z95m6
You're crazy.
Regardless, it shows Comp Cams is willing to assist now. SO trade them in for OEM style from them? Whatever happens, its better than complete denial from the company.
Old Sep 1, 2005 | 05:22 PM
  #68
Z95m6's Avatar
Comp is no more involved in this problem now then they were to begin with.
Old Sep 1, 2005 | 05:40 PM
  #69
When I have ever had a problem I always had replacement parts, new cams ground etc... as I said it's who you go thru and who you deal with.
I've had cams with soft lobes get replaced free of charge, cams with a wrong step in the nose of the cam (core supplier problem) replaced. Comp R's fail and replaced etc... getting thru to them takes a ton of time but I would most likely talk to the company that I bought the parts from if I was having a problem with Comp.
Good Luck guys, but I really don't think bitching anymore about it is going to solve anything, never has in the past.
The one other thing I would add is when you start modifing a stock motor parts are going to break, things happen, that's just racing there is no way around that other than being informed. Hell you even see the best prepared teams like Nextel Cup teams have engine problems because of faulty parts, this stuff will happen no matter how well you plan for it.
Bret
Old Sep 2, 2005 | 11:27 AM
  #70
Loadre's Avatar
FINALLY got ahold of somebody that was willing to get out of their chair at their desk. Wound up talking to the service manager. Got the same run around, .002-.004 preload, race lifter, constant adjusting, blah blah blah. Got my new set on the way though.
Edit - BTW if anybody wants them I've already got sealed power lifters in the car so I'm not gonna swap them back out since i'm not turning much RPM. I'll let them go for $165 shipped.
Old Sep 2, 2005 | 01:07 PM
  #71
Steves396lt1
Guest
Posts: n/a
Are your sealed power lifters quieter?
Old Sep 2, 2005 | 02:31 PM
  #72
Loadre's Avatar
By a decent bit they are quieter.
Old Sep 2, 2005 | 02:36 PM
  #73
Z95m6's Avatar
The sealed power lifters are just stock replacements right?
Old Sep 2, 2005 | 02:41 PM
  #74
Steves396lt1
Guest
Posts: n/a
I believe so. Also, what is the part number for these and price?
Old Sep 2, 2005 | 03:03 PM
  #75
Loadre's Avatar
Yes they are stock replacements.
Part # from advance auto is HT2148 and they were $13/per to the best of my recollection.
