Comp Cam Magnum 1.6's
Old Nov 20, 2008 | 06:49 PM
  #16
Originally Posted by 1993Fast_Z
so if i am not going higher than 6500, i can get SA's? i just dont want to jump a rocker or damage this engine, because it took me a long time to get the money for this engine...
There is no real RPM break that says one or the other. If you are that concerned NSAs are what you want.
Old Nov 21, 2008 | 04:47 PM
  #17
1993Fast_Z's Avatar
ok, thanks guys, much appreciated...sounds like im getting the NSA's
Old Nov 22, 2008 | 09:08 AM
  #18
96capricemgr's Avatar
Again to restate what was said the magnums are roller tip only, betting those who said they had them assumed "pro" Magnum and that is what they have not the roller tip only ones. Roller tip only is a joke, I personally would sooner run a long slot stamped without a roller tip. Fuller roller is the way to go though.
Guideplates are often cheap BUT I found the cheap ones did not fit right and ended up buying the $50 Isky adjustables after having tried the $20 Comps and the $20 GMPP, so basically I have spent $90 total on guideplates before I got it right.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
