Comp Cam Magnum 1.6's
There is no real RPM break that says one or the other. If you are that concerned NSAs are what you want.
Again to restate what was said the magnums are roller tip only, betting those who said they had them assumed "pro" Magnum and that is what they have not the roller tip only ones. Roller tip only is a joke, I personally would sooner run a long slot stamped without a roller tip. Fuller roller is the way to go though.
Guideplates are often cheap BUT I found the cheap ones did not fit right and ended up buying the $50 Isky adjustables after having tried the $20 Comps and the $20 GMPP, so basically I have spent $90 total on guideplates before I got it right.
Speeds8erM-1
Jul 18, 2002 11:36 PM
