Come to Stop, Oil goes to Zero!!??
Old Apr 29, 2005 | 10:27 AM
Deenasty's Avatar
I am posting this for friend who is having a realllly strange problem. It is a hotcammed 94 camaro, and when he comes to a fast stop, or is driving down hill, his oil pressure goes to zero, and his check gauges light pops up, for about 5-10 seconds, then goes away? We already did a oil change to make sure there is proper oil amount in the motor, but why is it doing this? Thanks Guys
Old Apr 29, 2005 | 10:28 AM
Dave89IROC's Avatar
Re: Come to Stop, Oil goes to Zero!!??
sounds like its either low on oil or the pick-up tube fell off
TransAm9585's Avatar
Not to be a bummer or anything but my car did this same type of thing before it finally lost all oil pressure. Spun a bearing. Id say be careful with it and have it checked real soon.
Old Apr 29, 2005 | 10:38 AM
Deenasty's Avatar
the funny thing is this is a brand new lt4 bottom end. He spun a bearing in his old motor, and this one is brand spanking new. Id say it has 1000miles on it the most. So you think the oil pick up tube could have came off huh...Do you mean the one in the intake manifold, or the one attatched to the oil pump?
Old Apr 29, 2005 | 10:49 AM
turbo_Z's Avatar
Attached to the pump. A way to check is drain the oil then hit the bottom of the pan with a rubber mallet and listen for anything bouncing around in the pan... that would be the pickup tube.
Old Apr 29, 2005 | 10:51 AM
Deenasty's Avatar
Great, thanks for the Idea, I would have never though about it. Thanks A lot guys, I will have my friend come over and we can try this. Thanks Guys!
Old Apr 29, 2005 | 11:20 AM
Red96Lt1's Avatar
mine did that and it was the pick up tube.
BigWil
Mar 29, 2015 12:24 PM
MattFick
Feb 15, 2015 10:16 PM
Scottylt1
Jan 8, 2015 02:48 PM
phoenix95
Jan 8, 2015 02:44 PM
Scottylt1
Dec 4, 2014 12:31 PM
