Collapsing lifter - How much spring pressure?
Old Apr 21, 2003 | 02:53 AM
  #16
Don 97 SS's Avatar
Originally posted by Mindgame
Oh sure, I agree on that!
A billet cam is a bit tougher but they'll die just like anything else. The diagnosis is hard to determine though. I don't doubt that it could be the product of excessive spring pressure but I'd be looking elsewhere first. Namely the tappet bore relation to the camshaft. Or maybe oiling problems in that area.
Alot of this kind of 'on-the-edge' performance stuff really calls for professional-level-competition-type engine work.
-Mindgame
I will have to agree based on my recent experience. I had a top end kit installed with a custom mild grind billet cam under oem lifters for about 30k miles over 4 years. When I pulled it recently the cam and lifters showed damage. Several of the lobes were badly scored. The car was a driver and well maintained. Oil pressure was good. I've showed that cam to several engine builders and no one could positively identify what happened.
I've replaced the cam and lifters along with some springs and timing set, but am concerned if it will reoccur.
Old Apr 21, 2003 | 07:09 AM
  #17
rskrause's Avatar
Moderator
I don't that the selling point of a "billet" cam was ever hardness of the lobe surface anyway. It's supposed to be stronger in cross section.
Rich Krause
Old Apr 21, 2003 | 08:54 AM
  #18
CANTONRACER's Avatar
I also got the GTP-6 cam going in my 388" stroker. I will be using the 977's and the question I have is I have a Hydra-Rev kit. Do I still need with these springs?
Old Apr 21, 2003 | 09:28 AM
  #19
96speed's Avatar
From searching through some posts of his, I understand Mindgame likes the revkits because of their ability to stop collateral damage, but I'll let him answer that for sure.
For a while a head porter on this board preached that they were basically a bandaid for improper spring selection and not necessary, but I like to take the advice of guys who are (much) faster and experienced than me .
I had picked up a billet GTP cam last year, but after taking it to GTP, Craig believe that the lobe damage (tracking out) was due to inadequate spring pressures (among other variables).
Ryan
HectorM52
Jul 30, 2017 11:46 AM
Sauced
Apr 12, 2015 10:18 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
jj_burchiel
Mar 5, 2015 07:05 AM
alex5366
Feb 17, 2015 08:12 PM
