coil replacement
Old Mar 19, 2004 | 09:47 PM
mariusz's Avatar
coil replacement
Hi. Is it recomended to replace the coil module
when replacing the coil? 88,000 miles on both.
Old Mar 19, 2004 | 09:50 PM
ArizonaZ's Avatar
I don't think it is recommended, but you can always go with a MSD coil and Module. Probably together they are $200, but I think well worth it.
The module usually works or doesn't. I don't see a need to change one that is working.
Old Mar 19, 2004 | 09:53 PM
mariusz's Avatar
Thanks guys!
Old Mar 19, 2004 | 10:15 PM
OBE1 95Z28's Avatar
I've got 143K miles on my original ignition module with no problems. I did own a MSD coil for 10K miles and it crapped out. Presently running a Crane coil with no issues for 40K miles.
Old Mar 21, 2004 | 07:06 AM
Eliminator's Avatar
Do you gain anything by replacing Stock Coil? I heard it will burn fuel at a better rate then stock. Like if you run a higher octane gas it will burn it better??? Do you have a Part # and price for Crane Coil? Aslo what would have caused the MSD Coil to crap out that early?
Klypto
Mar 23, 2016 09:05 AM
grabbem88
Mar 18, 2015 01:25 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
