Coil is arcing between the 2 plugs
Old Nov 25, 2003 | 09:39 PM
bigjoebull's Avatar
My car just started idling real ruff and lost a little power. You can hear and see the coil arcing between the pugs (coil wire and wiring harness plug). What would cause this and could it cause damage if I drive it home? The wire to the opti looks to be in good cond..
Old Nov 25, 2003 | 10:27 PM
Make sure the area is clean. You could also put some dielectric grease on the inside of the coil wire boot to see if that helps any. Could also be that your coil wire is just leaking spark and may need to be replaced.
Old Nov 26, 2003 | 07:43 AM
bigjoebull's Avatar
OK thanx I also noticed today that there is only one bolt still in the bracket.
Old Nov 26, 2003 | 04:36 PM
bigjoebull's Avatar
Today I put a new coil wire on and it still had a little arc, but then it started arcing somewhere on the passenger side. Do I need new plug wires also or ?
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
greenzee28
Mar 26, 2015 09:13 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
captcorvette
Mar 7, 2015 12:37 PM
