Canister Removal
Old Nov 26, 2003 | 12:17 AM
Camaroz28lt1383's Avatar
Canister Removal
Can you plug the line that comes out of the fuel tank that goes to the charcoal canister, once you remove it, and the one that goes to the throttle body? Thanks
Old Nov 26, 2003 | 12:33 AM
Shelldust's Avatar
Id say probably, but if I was you Id get either a vented gas cap or I would put a filter on the end of the lines. Fumes might be bad too unless u route the lines under the car. Just my two cents
Old Nov 26, 2003 | 02:41 PM
OBE1 95Z28's Avatar
The gas cap needs to remain sealed as it's a presurized system. There is already a pressure release valve that is plumbed into the gas tank if pressures were to become excessive.
Old Nov 26, 2003 | 03:19 PM
Shelldust's Avatar
Oh, shows how much I know I guess
Old Nov 26, 2003 | 04:45 PM
Why do you want to remove the canister?
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
RX Speed Works
Sep 11, 2015 03:31 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
350350
14
Aug 11, 2015 12:03 PM
