Codes being thrown..Help me!
Old Jun 22, 2005 | 05:18 PM
flyinZ's Avatar
Code 33-(MAP sensor high),Code 42-(EST grounded), Code 83-TCC Control feedback fault.
Anybody know whats goin'on here?? I recently did a BRE cam/spring swap, and these showed up after intial startup..No miles on the parts,either..(i also have a knock sound,as well.
Old Jun 22, 2005 | 05:27 PM
97LTImike's Avatar
Thumbs up Re: Codes being thrown..Help me!
I would run by your local ASE certified shop for a quick scan.
Old Jun 22, 2005 | 05:29 PM
97LTImike's Avatar
They'd be able to pin point the problem and tell you what the heck is going on. I had a problem similar a while back.
Old Jun 22, 2005 | 05:33 PM
flyinZ's Avatar
I just scanned them with Tunercat..CD 33 has to do with low vaccum(yes, it has a rough idle), CD 42 has to do with ignition control( just replaced everything to do with ignition), and CD 83 has to do with the TCC control solenoid..But why!!!!
Old Jun 22, 2005 | 05:37 PM
97LTImike's Avatar
Could it be your o2 sensors? How is your o2 reading?
Old Jun 22, 2005 | 08:46 PM
"Big" cams will produce high MAP readings (= low vacuum) that exceed the threshhold at idle for the DTC 33 code. I think it would indicate you are seeing MAP readings over 68kPa. Could be the cam, could be the "tune", could be the valve adjustment.
DTC 42 is a short or ground on the ignition. Clear it and see if it comes back. Could be a stored code from a problem at initial startup. How's it running?
DTC 83 = TCC PWM Solenoid Circuit Fault (automatic transmission)
Old Jun 23, 2005 | 09:40 AM
flyinZ's Avatar
The first code doesn't suprise me, since the pcm isn't tuned for this cam yet, and yes, its a pretty good size cam . Will tuning fix this problem?
Since my last setup, I have changed ignition setups, went from a Delteq, back to an Opti/coil setup,so I could have something hooked up wrong, I'll have to double check things, and clear that code out..
Whats the last code mean, about the TCC solenoid? Does that mean its going bad? How hard is that to replace?
Thanx guys!
Old Jun 23, 2005 | 05:33 PM
I would reset the PCM and see what comes back.
Old Jun 23, 2005 | 09:20 PM
flyinZ's Avatar
I unhooked the battery cable a few times, throughtout this process, and the SES light always seems to come back...Is there another way to reset it?
Old Jun 23, 2005 | 10:19 PM
That's the hard way to reset it, but it will work. You can simply remove the PCM BAT fuse for 30 seconds or so.
Old Jun 24, 2005 | 01:51 PM
You can't "reset" it if the problem is till there. You need to scan it again and see which of the codes came back.
Old Jun 24, 2005 | 02:10 PM
04toy's Avatar
Also check the ground strap from the ICM to the radiator support. I ended up replacing the opti, icm and pcm before I decided to check this and it was causing all kinds of issues with my car. Was getting the Code-42. If that does not fix it check your ICM connectors, might be an issue there. Last but not least, are you using a GM ICM or an AutoZone equivlant? The AutoZone ones have been bad for me straight out of the box.
Old Jun 29, 2005 | 09:37 AM
themessageboard's Avatar
Does removing the fuse clear the codes completely so the PCM will have to read those errors again before the SES light comes on???
Old Jun 29, 2005 | 10:34 AM
Yes.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
