Codes being thrown..Help me!
Code 33-(MAP sensor high),Code 42-(EST grounded), Code 83-TCC Control feedback fault.
Anybody know whats goin'on here?? I recently did a BRE cam/spring swap, and these showed up after intial startup..No miles on the parts,either..(i also have a knock sound,as well.
Re: Codes being thrown..Help me!
I just scanned them with Tunercat..CD 33 has to do with low vaccum(yes, it has a rough idle), CD 42 has to do with ignition control( just replaced everything to do with ignition), and CD 83 has to do with the TCC control solenoid..But why!!!!
"Big" cams will produce high MAP readings (= low vacuum) that exceed the threshhold at idle for the DTC 33 code. I think it would indicate you are seeing MAP readings over 68kPa. Could be the cam, could be the "tune", could be the valve adjustment.
DTC 42 is a short or ground on the ignition. Clear it and see if it comes back. Could be a stored code from a problem at initial startup. How's it running?
DTC 83 = TCC PWM Solenoid Circuit Fault (automatic transmission)
The first code doesn't suprise me, since the pcm isn't tuned for this cam yet, and yes, its a pretty good size cam
. Will tuning fix this problem?
Since my last setup, I have changed ignition setups, went from a Delteq, back to an Opti/coil setup,so I could have something hooked up wrong, I'll have to double check things, and clear that code out..
Whats the last code mean, about the TCC solenoid? Does that mean its going bad? How hard is that to replace?
Thanx guys!
. Will tuning fix this problem? Since my last setup, I have changed ignition setups, went from a Delteq, back to an Opti/coil setup,so I could have something hooked up wrong, I'll have to double check things, and clear that code out..
Thanx guys!
Originally Posted by flyinZ
I unhooked the battery cable a few times, throughtout this process, and the SES light always seems to come back...Is there another way to reset it?
Also check the ground strap from the ICM to the radiator support. I ended up replacing the opti, icm and pcm before I decided to check this and it was causing all kinds of issues with my car. Was getting the Code-42. If that does not fix it check your ICM connectors, might be an issue there. Last but not least, are you using a GM ICM or an AutoZone equivlant? The AutoZone ones have been bad for me straight out of the box.
Originally Posted by themessageboard
Does removing the fuse clear the codes completely so the PCM will have to read those errors again before the SES light comes on???
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
Jul 8, 2002 01:37 AM
