Codes 48, 64 & 34......
Old Feb 16, 2004 | 04:17 PM
  #16
slider's Avatar
Originally posted by Injuneer
Just because the code says the O2 sensor is readking "lean" doesn't mean that there is a problem with the sensor. It might acutally be running lean.... large vacuum leak, low fuel pressure.... or it might be a "false" lean.... exhaust leak before the O2 sensor, misfires, etc.
Since you have posted scan data elsewhere, why not use your scanner to look at the long term fuel corrections in as many of the 16 operating "cells" as you can. Somewhere in there, it is likely you have a cell that is maxed out at 160, and still isn't adding enough fuel to correct what the PCM "thinks" is a lean condition.
You also need to look at the long term corrections for both banks... if only one bank is running lean, it tells you its a problem that only affects that side. If both banks are running lean, its a problem that is affecting both sides.
I'm not really sure how to read all this junk
Old Feb 16, 2004 | 04:51 PM
  #17
Skedaddle's Avatar
The guy spends all that time trying to help you, and you call it "junk"?
Old Feb 16, 2004 | 05:55 PM
  #18
slider's Avatar
You misunderstood. I didn't mean literally junk. I was referring to the readings and all from Datamaster. I really don't know what to make of all of it is what I was saying. Thanks for your helpful post.
Old Feb 16, 2004 | 10:20 PM
  #19
JDBlaze85's Avatar
take a chill pill skedoodle
so exactly how many cells are in the LT1 PCM? LS1 PCM?
Old Feb 17, 2004 | 06:35 AM
  #20
You might want to read my online scanner writeup.
Some more junk
Old Feb 17, 2004 | 10:49 AM
  #21
slider's Avatar
Anyone know where I need to look in datamaster to find these "cells"?
Old Feb 17, 2004 | 11:16 AM
  #22
"Fuel Trim Cell #"
Old Feb 17, 2004 | 07:36 PM
  #23
Lyle A's Avatar
Some more junk
Hey, that's great junk. It makes me more edjumicated. Thanks alot!
Old Feb 18, 2004 | 02:06 AM
  #24
JDBlaze85's Avatar
alot of good junk in there Injuneer.
Question:
If you are getting knock retard while going down the track using high octance fuel and spraying nitrous..........
what do you do to correct this?
adjust timing
delete the knock sensor........
or would you have higher power tuning the engine until there is no knock detected??????????????
or none of the above?
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
