Code P412, Fuse Blows, Mechanic said:
Old Jun 23, 2003 | 03:14 PM
kimquigley's Avatar
I bought my 96 Z in August and about every 3 months since then, my SES light comes on showing Code P412 and the #7 fuse under the hood is blown. I have a fuse kit, so it's not a big deal to replace the fuse, but this shouldn't be happening all the time.
It happened again over the weekend so I took it to a Tires Plus and they said that this is a common problem with Camaros and the solution is to replace the wire and fuse size and the air pump. They said it will cost $425.
There's a recall on those parts but my VIN doesn't fall in the range of cars that had the recall. I wonder if I can convince GM that it should.
Has anyone had this problem or attempted to install the repair kit without the help of a mechanic?
I don't have $425...
Old Jun 23, 2003 | 03:26 PM
joeSS97's Avatar
If you dont have to deal with emissions testing,I would remove the AIR pump.Get the PCM reprogrammed and you are set.Probably the pump is going out.
Old Jun 23, 2003 | 03:40 PM
If you want to/have to keep the AIR pump, take it to your friendly dealer..... this is such a common problem that there is a recall on 95 and up AIR pumps.
Old Jun 23, 2003 | 04:13 PM
x7x7's Avatar
I also have a '96 and my car was eligable for the recall. even got a letter in the mail. Take it to the dealer and tell them what's going on, they should replace the pump.
Old Jun 23, 2003 | 06:57 PM
Mtrhds94Z's Avatar
THIS is the lesser known air pump TSB 'wiring/fuse upgrade' that the mechanic was probably referring to:
http://web.archive.org/web/200111080.../63-65-02.html
Also there is 'air pump recall campaign #99083', which replaces the air pump only...
http://web.archive.org/web/200104181...egg/99083.html
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Britbilly
Jan 7, 2015 08:49 PM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
