Code P1441 ???
Old Mar 31, 2007 | 01:29 AM
dregsz's Avatar
Code P1441 ???
<You are OBD-II and the cheapest thing would be to go to Autozone and let them scan it for free. Make sure you get the exact code from them and come back here for more help.>
Hi All, Thanks for the advice,
I went to A Zone and got the P1441 code.
She called it a "manufacturer's code" and had no info on it.
What does it mean?
Car seems to be running ok...
Evan
Old Mar 31, 2007 | 01:33 AM
dregsz's Avatar
did a search,
got thisL
http://web.camaross.com/forums/showt...ighlight=p1441
I hate this kind of PIA ****.
I have to smog it in like a week.
Yuck
Old Mar 31, 2007 | 01:54 AM
ZX636RIDER03's Avatar
it might be your egr valve i had the same code before and many others but that was one of them. or maybe your charcol filter connections.
Old Mar 31, 2007 | 02:13 AM
dregsz's Avatar
I just searched and read alot about cabon in the line etc.
So is one end of this line on the canister in the driver's rear fender well and the other end up off the solinoid at the passenger valve cover?
Exactly where are the ends of the line locatd that I need to remove and which side do I blow the air through?
Evan
Old Mar 31, 2007 | 07:47 AM
What the heck would the EGR valve have to do with the EVAP system?
P1441 = Evaporative Emissions (EVAP) system flow during non-purge
refer to diagram
That means that the vacuum switch (#11) detected the presence of vacuum when there was not supposed to be any (when the solenoid was supposed to be off). Check for the presence of charcoal in lines #1 and #2. #2 is wrapped with the fuel lines and goes back to the charcoal canister in the RH wheel well. That is where you could disconnect it and blow it out, if needed.
Also check #11 and #7 (the solenoid) for any charcoal contamination. Your solenoid could be stuck open (in which case, you would be able to draw air through both ports on it when it was not operated). Or the vacuum switch could be faulty and reporting the condition in error.
If you want to know what a DTC means in the future, click the DTCs link in my sig for codes specific to 93-97 f-body cars. You might also want to visit my Tech Page for all kinds of other info that might help you out.
Old Mar 31, 2007 | 01:05 PM
Originally Posted by Evan Ginsberg
OK, Some Guy hijacks my thread about the EGR and then you bust my chops over it??
I just want to know where to take the lines off and which side to blow from thanks for reprimanding me like a schoolgirl, I don't get enough of that at home from my wife
Cool down... you totally misunderstood Shoebox. He was jumping on the "some guy" (ZX636RIDER03) that sidetracked the thread with an erroneous comment abuot the EGR.
In effect, you've just blown off the most knowlegable, helpful and friendly guy on this entire site.
Good luck getting help. I know I'd think twice before getting into this thread.
Old Mar 31, 2007 | 11:51 PM
I know Shoebox is "Da Man" imagine how I feel getting slammed by him for some other Bozo's mistake.
Dude, go back and re-read. My comment was not toward you. I posted a long explanation with a diagram to help you. Oh, well...
Old Apr 1, 2007 | 01:05 AM
dregsz's Avatar
Thanks, I'll clean this up, I thought, you thought I posted that. I appreciate
your diagrams and assistance
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
