code P0118
code P0118
my car is throwing this code and i looked in my haynes book and i could not find were it is located. could some one tell me were it is at and take a picture of or find a picture so i no what it looks like.
Do you have an AutoZone or other store nearby? Autozone and otheres will scan your vehicle and tell you what your codes mean. And if you are lucky might clear the code if it is no biggie. I believe you can disconnect you bat and it will also reset (of course you do not want to ignore anything that is important. JMHO
Look the codes up on Shoebox's LT1-specific list. Much more reliable than the generic code descriptions a scanner will put out.
http://shbox.com/1/Dtcs.htm
The sensor is in the water pump housing, again the photo, courtesy of Shoebox:
http://shbox.com/1/temp_sensor1.jpg
ya i no what the codes means i just dont no where it is located or even what is looks like. and my car is a 96 so it has the OBD II and I have a scanner and i have erased the code times now and it keeps coming back so i now it is bad.
Not directly related, but everytime I try to get a new temp sensor for the head from Checkers, they give me one with 2 wires and mine only has one... what gives? They only have 2 wire ones, do I have to modify one of these to work, and if so how do I do it?
Jonota
Jonota
Sounds like you replaced the sensor in the head, rather than the one in the water pump. Did you even look at the photo link I posted?
Yes Fred, that's the one in the water pump, it works fine, the one for my dash gauge isn't working. But Checkers (which is really the only decent parts store in Hawaii) doesn't have ANY temp sensors with only one wire, everything they show me has 2. I'm afraid if I have autozone or someone better than Checkers ship me one it will be the 2 wire one.
Jonota
Jonota
Jonota
Jonota
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
Jul 8, 2002 01:37 AM
