code P0118
Old Jun 4, 2007 | 11:13 AM
96camaroz281988's Avatar
code P0118
my car is throwing this code and i looked in my haynes book and i could not find were it is located. could some one tell me were it is at and take a picture of or find a picture so i no what it looks like.
Old Jun 4, 2007 | 01:54 PM
2000GTP's Avatar
P0118= Engine Coolant Temp sensor circuit high voltage. Its possible you may have a bad ECT sensor.
Old Jun 4, 2007 | 02:21 PM
BUBBA's Avatar
Do you have an AutoZone or other store nearby? Autozone and otheres will scan your vehicle and tell you what your codes mean. And if you are lucky might clear the code if it is no biggie. I believe you can disconnect you bat and it will also reset (of course you do not want to ignore anything that is important. JMHO
Old Jun 4, 2007 | 04:25 PM
Look the codes up on Shoebox's LT1-specific list. Much more reliable than the generic code descriptions a scanner will put out.
http://shbox.com/1/Dtcs.htm
The sensor is in the water pump housing, again the photo, courtesy of Shoebox:
http://shbox.com/1/temp_sensor1.jpg
Old Jun 5, 2007 | 11:39 AM
ya i no what the codes means i just dont no where it is located or even what is looks like. and my car is a 96 so it has the OBD II and I have a scanner and i have erased the code times now and it keeps coming back so i now it is bad.
Old Jun 5, 2007 | 11:41 AM
moparman's Avatar
Fred posted a link to a photo of where the sensor is located.
Old Jun 5, 2007 | 11:46 AM
i just replaced that a couple of months ago and i have only driven my car 2 time since then. do you guys think it could of went baad the quick.
Old Jun 5, 2007 | 01:09 PM
2000GTP's Avatar
Hard to say for sure, but if you have a multimeter, you can do a diagnostic on it and see. Shoebox has a good guide: http://shbox.com/1/4th_gen_tech2.html#ect
Old Jun 5, 2007 | 01:22 PM
JAB's Avatar
JAB
Make sure you didn't bend the pins of the connector. I did that once and it wouldn't make a circuit because of no contact.
Old Jun 10, 2007 | 06:04 PM
jonota's Avatar
Not directly related, but everytime I try to get a new temp sensor for the head from Checkers, they give me one with 2 wires and mine only has one... what gives? They only have 2 wire ones, do I have to modify one of these to work, and if so how do I do it?
Jonota
Old Jun 10, 2007 | 07:35 PM
JAB's Avatar
JAB
They're giving you the wrong sensor. The sensor in the water pump is the two wire sensor. The head only has the one wire. I'd find a new parts store.
Old Jun 11, 2007 | 10:19 AM
Jonota
Sounds like you replaced the sensor in the head, rather than the one in the water pump. Did you even look at the photo link I posted?
Old Jun 11, 2007 | 01:15 PM
jonota's Avatar
Yes Fred, that's the one in the water pump, it works fine, the one for my dash gauge isn't working. But Checkers (which is really the only decent parts store in Hawaii) doesn't have ANY temp sensors with only one wire, everything they show me has 2. I'm afraid if I have autozone or someone better than Checkers ship me one it will be the 2 wire one.
Jonota
Old Jun 11, 2007 | 02:12 PM
moparman's Avatar
You may have to go to the dealer.
Old Jun 11, 2007 | 05:42 PM
Jonota
That's what is bound to happen when you highjack someone's thread... you've been around here long enough to know that
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
