code 84
Old Jun 16, 2007 | 07:56 PM
BLDun's Avatar
code 84
I keep getting a code 84 - I know it has something to do with the skip shift but what does it entail and would it affect anything else???
Old Jun 17, 2007 | 09:10 AM
Guest47904's Avatar
Guest
Nothing else happens. The PCM is reporting that it is not seeing voltage on pin B13 of the Black PCM connector (grey) wire. Either you have a wiring issue or the solenoid it disconnected. It wouldn't be a fuse problem since you are not getting codes for EVAP or EGR or O2 heaters.
If you want to eliminate the code and leave off the CAGS put a relay coil in the socket in place of the solenoid.
Old Jun 17, 2007 | 11:29 AM
The code can be eliminated by putting a 2.2Kohm resistor in the harness connector.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
