code 84
Nothing else happens. The PCM is reporting that it is not seeing voltage on pin B13 of the Black PCM connector (grey) wire. Either you have a wiring issue or the solenoid it disconnected. It wouldn't be a fuse problem since you are not getting codes for EVAP or EGR or O2 heaters.
If you want to eliminate the code and leave off the CAGS put a relay coil in the socket in place of the solenoid.
johnsocal
08-29-2002 10:01 AM
Darth Xed
14
08-07-2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
07-08-2002 01:37 AM
