Code 52
Old Oct 23, 2005 | 09:15 PM
craigffb's Avatar
Code 52
I'm getting a code 52, engine oil temp sensor low, on my Auto Xray that will not clear. I didn't think the LT1 had an oil temp sensor and I can't find any thing in the Haynes manual about it. What gives?
Old Oct 23, 2005 | 09:31 PM
Re: Code 52
Are you using the correct setup on the scanner for your car or just a generic OBD-I setup? It should not be telling you anthing about an oil temp sensor problem, because the F-body does not have it.
Old Oct 23, 2005 | 10:17 PM
craigffb's Avatar
Re: Code 52
It doesn't let me pick F-Body if that's what you mean. Just the engine code and year. The PCM has been re-flashed with a PCMforless program as well. I guess I have nothing to worry about right??
Old Oct 24, 2005 | 07:53 AM
Re: Code 52
You're ok.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
