code 34 - map flatline on datamaster
Old Aug 14, 2008 | 06:10 PM
mikeRv6's Avatar
Datamaster shows code 34 - the map sensor is flat lined at 10.6 kpa (I mean no change at all under any throttle or load condition)
So I replaced the pigtail and am reasonably confident that I crimped it in correctly, but still no change, sensor remains at 10.6
I to get about 4.8 volts at the unplugged pigtail when jumping green and black, key on engine off.
Map is clear of oil, orange seal seems fine
Question:
How do I check voltage with my multimeter while the pigtail is plugged into the sensor?
What else should I check before buying a new map?
thanks
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
tbyrne
Jul 2, 2002 05:37 PM
