Code 32 EGR fault
Old Jul 5, 2004 | 01:01 PM
ukfirehawk's Avatar
Code 32 EGR fault
If I'm driving in a lazy manner - 65 MPH or so in 6th gear - I frequently throw code 32 - EGR I believe. The car runs fine still and the SES resets on the next startup. I stress that this only happens when being lazy in top.
Any suggestions would be welcome.
Old Jul 5, 2004 | 01:17 PM
Unusual to get DTC 32 on an OBD-I car, but it is possible. In your case, only happening at low rpm in a high gear (exactly the time EGR is needed), could be a combination of low exhaust back pressure and a partially plugged EGR valve/passages. Might want to pull the valve and try cleaning it.
Old Jul 5, 2004 | 02:31 PM
ukfirehawk's Avatar
Many thanks - recently installed Pacesetter shorties and the car runs and SLP TODL so that would concur with your low back pressure idea I guess.
timmy39120
May 8, 2015 11:41 AM
markzzzz
May 8, 2015 09:21 AM
May 1, 2015 01:14 PM
edman
Mar 13, 2015 09:39 PM
91Bird305
Aug 5, 2002 01:39 PM
