Code 24 need help.
Old Aug 4, 2004 | 04:19 PM
INFERNO's Avatar
Question Code 33 need help.
I am getting my car dyno tuned on saturday and I have a code that keeps popping up the code is 33 on a 1993 Z28. The code is map sensor voltage high vacuum low. I have a CC306 cam and Lloyd Elliot heads on the car. Is there any reason that this code is setting. I am thinking it becuase of the low vacuum created by the cam. The map sensor is operating normally and was replaced. Anyone have this problem? Thanks.
Old Aug 5, 2004 | 05:33 PM
INFERNO's Avatar
Re: Code 24 need help.
TTT no one had this problem?
Old Aug 5, 2004 | 06:30 PM
Are you sure it is 24? That's not a MAP code.
Old Aug 6, 2004 | 12:24 PM
INFERNO's Avatar
Re: Code 33 need help.
Sorry Code 33. Thanks
Old Aug 6, 2004 | 12:34 PM
If the rpms and vacuum get too low, the computer won't like the MAP reading. It is expecting to see readings in a certain range based on rpm and such. If the MAP gets too low, it will throw the code.
99z28 carguy
May 26, 2015 11:35 AM
beltrunner
May 17, 2015 10:18 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Dec 23, 2014 07:52 AM
91Bird305
Aug 5, 2002 01:39 PM
