Code 23 and 25
Old Mar 10, 2010 | 09:37 PM
BUDZ28's Avatar
Code 23 and 25
hi, first time on here. i have a 1993 z28 with an LT1 6spd. just bought the car a week ago and have been coming up on a lot of problems i think were caused by last owner. i bought a GM code reader and im getting code 23 and 25. car starts good, has good idle just under 1 grand and stays steady. if im gentle on the gas ride is rather smooth, but if i floor it the car will sputter around 2500 and then smooth out at about 3 grand. changed plugs, didnt get to wires. new in line fuel filter. car doesnt have MAF sensor installed. also previous owner removed IAT sensor, wires still there but sensor gone. whole is open where sensor goes. im kinda lost, and not to sure if any of this helps. i would appreciate any help. thank you!
....sorry so long. also a buddy of mine called a friend whos GM certified. he said i should replace my TP sensor.
Old Mar 11, 2010 | 05:28 AM
The codes are both for the missing IAT sensor. Replace the sensor, and verify that the wires are not damaged.
1993 is the only year F-Body LT1 that does not use a mass air flow (MAF) sensor to measure air flow into the engine. Your ECM reads the inlet air temp (IAT) and the manifold absolute pressure (MAP) and calculates the mass air flow based on RPM, displacement and volumetric efficiency. If the PCM does not have a correct inlet air temp, it can't calculate the mass air flow correctly, which means it can't know how much fuel to add to maintain the required A/F ratio. It will use a default calculation, that will not provide optimum power or response to throttle changes - exactly what you are experiencing.
In addition to screwing up the ECM's A/F calculation, the hole for the missing IAT sensor is allowing unfiltered air to enter the engine.
Old Mar 11, 2010 | 08:37 AM
BUDZ28's Avatar
ok sounds good. im gunna replace the iat and check wires. hope this fixes it, thanks!
Old Mar 11, 2010 | 09:06 PM
BUDZ28's Avatar
my baby is alive!! ok IAT is in and no more sputtering around 2 grand. even took her for a little spin around the block. thanks a lot!!
Old Mar 11, 2010 | 09:23 PM
No wonder. The IAT is crucial for your 1993 speed density engine to run properly.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
