Code 18
Old Mar 9, 2011 | 10:09 PM
Bigjaycass's Avatar
Code 18
I am getting a code 18 on my 1995 z28. The car is running very rich, BLM on right side is at 160. The O2 sensor on right is jumping around like it should and the left O2 is hanging around .250, after warm up. I thought the drivers O2 was bad, so I changed it with same results. The car runs great when cold and stumbles on take off when warmed up. If I get on it a little harder it clears up pretty good. Now I know the code 18 is something with the injection system, has anyone else experienced this problem before? Oh, car has a CAI, headers, and flowmaster exhaust, that's all.
Old Mar 9, 2011 | 11:09 PM
Re: Code 18
You should be electrically checking the injectors and their circuits. That's what code 18 is about.
Old Mar 10, 2011 | 12:19 PM
Bigjaycass's Avatar
Re: Code 18
Leaky injector wouldn't set that code off would it?
Old Mar 10, 2011 | 05:42 PM
bw_hunter's Avatar
Re: Code 18
The PCM would have no clue that an injector is leaking. Check the electrical side of things......as Rob suggested.
Old Mar 12, 2011 | 06:33 AM
Re: Code 18
Key on, check for 12V on the pink wire at each injector. Then check the resistance of each injector (harness connector unplugged). Should be 12-15 ohms. Finally, us a 'noid light to verify the PCM is providing the ground to fire each injector.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
