TPS Sensor
Old Mar 10, 2011 | 08:24 AM
rocknroler69's Avatar
TPS Sensor
I just put on a 52 mm tb and now am going to check my tps sensor with a dmm. What should I have for a reading, I can't find a spec anywhere
Old Mar 10, 2011 | 11:18 AM
transAMdriv3r's Avatar
Re: TPS Sensor
i belive its .68 volts
Old Mar 10, 2011 | 04:50 PM
RamAir95TA's Avatar
Re: TPS Sensor
Between .23v and .9v at idle (closed). When you open the throttle the voltage should increase smoothly and peak at WOT (with the PEDAL, not your hand) about 4v higher than your idle voltage. For example, if your idle voltage is .6v, then your WOT voltage should be approximately ~4.6v. If the voltage goes past ~5v you'll get an SES light for TPS voltage HIGH.
Old Mar 10, 2011 | 09:06 PM
Re: TPS Sensor
Is there any type of adjustment I could do if its not withing spec?
Old Mar 10, 2011 | 10:00 PM
Re: TPS Sensor
With-in*
Old Mar 10, 2011 | 10:39 PM
Re: TPS Sensor
Slot the mounting holes and rotate it until you get the reading you want.
Old Mar 12, 2011 | 06:37 AM
Re: TPS Sensor
Before you check the TPS voltage:
-verify the idle speed is within spec. The throttle stop screw may not be adjusted correctly, and that would affect the TPS reading.
-verify the IAC counts are between 20-40 counts. That verifies the throttle position. (you need a scanner or scan software to read this value from the PCM).
-now check the TPS voltage.
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
