Code 16 Lo-Res Failure???
Old Oct 23, 2003 | 10:54 AM
twdz28's Avatar
Question Code 16 Lo-Res Failure???
Early this morning i had a code 36 Hi-Res Failure so I change the Opti with one I had in the garge... Now im getting a Code 16 Lo-Res Failure what does this code mean???
Thanks for any help in advance....
Old Oct 23, 2003 | 10:57 AM
If the engine is running, its a "stored" code. Probably set when the PCM tried to synch with the Opti on initial startup. Clear it and see how soon it comes back. I would also make sure the harness connector is clean and not damaged, and no high voltage wires located too close to it.
If its an "active" code, the engine wouldn't be running. PCM shuts down the fuel system on loss of low res pulse.
Old Oct 23, 2003 | 11:04 AM
twdz28's Avatar
I cleared the codes just before starting the car... The car started well kinda it never run above 400 RPM... That when it flashed code 16...
Old Oct 23, 2003 | 12:27 PM
.... and stopped? Would not restart? Not clear on exactly what happened.
If it won't start, and you are getting only DTC 16, either the harness wire that carries the low res pulse from the Opti to the PCM is faulty, or the optical module in the Opti is deceased. One other remote possibility that I alluded to earlier - if you have some high voltage wires too close to the Opti harness, it can induce signals in the harness wire that corrupt the pulse pattern.
Old Oct 23, 2003 | 12:51 PM
twdz28's Avatar
the car died..... well i did as you said and cleaned all the wires and made sure everything was out of the way... the car started and ran well... thanks....
but wait it want start again... im clueless now...
oh and if you have free scan hooked up to your car and the battery on the car dieds do i need to worry about my pcm being fried??? that just happend to me... Oh well I guess I will get the battery charger out...
May 1, 2015 01:14 PM
Chet1185
Apr 26, 2015 04:07 AM
Injuneer
Dec 15, 2014 09:36 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
